Golf mk5
bad day car broken :-(
Topic: bad day car broken :-( (Read 3002 times)
justalex81
09 February 2014, 18:45 »
I have a 1.9tdi sport on a 55 plate. Driving along when i get a slight thud and a loss of power. manage to coast it to a layby and call AA. he manages to start it and it idles but very rough. blue smoke out the exhaust. He removes the dipstick and it spits oil all over him!!!
So my guess is piston rings but i don't know an awful lot about this engine. Hoping it isn't so. Any thoughts guys?
For all Domestic and Commercial gas,heating and hot water needs.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: bad day car broken :-(
10 February 2014, 18:28 »
Quote from: justalex81 on 09 February 2014, 18:45
Was this with engine running? Crank case breather all gunked up?
Wayne
Sir Postalot
10 February 2014, 22:04 »
How many miles has it done.
justalex81
11 February 2014, 09:52 »
115k miles. serviced every 7k since i owned it.
a blocked breather wouldn't cause blue smoke out the exhaust would it???
i thought blue smoke = oil in the explosive chamber
madmanmart
11 February 2014, 21:05 »
Turbo?
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Wayne
Sir Postalot
11 February 2014, 21:46 »
Well blue smoke is oil being burnt, I would start be getting a compression test carried out, if within spec then you can rule out an engine problem.
You could have an injector or fuel pump issue, it could be burning excess fuel.
itavaltalainen
Reply #6 on:
11 February 2014, 22:53 »
if the breather pipe is so gunked up it's shut then the crankcase does not have a possibility to vent - typically this leads to overpressure....
could also just be that it has a lot of oil in intercooler...
would check into that before ripping turbo out.
justalex81
Reply #7 on:
12 February 2014, 01:57 »
will do pressure test first. i hope it isn't piston or rings but i can't see what else could cause all this to happen at once.
justalex81
Reply #8 on:
10 March 2014, 23:22 »
it was the turbo in the end. impeller snapped in half!
Golf mk5
