Author Topic: Rear wiper doesnt work  (Read 1290 times)
Offline D4VEY01
  • 1999 GTI 1.8T AGU BLACK
« on: 09 February 2014, 14:46 »
Rear wiper wont work,fuse ok,is it on a separate relay than the front wipers,,,or any ideas
Thanks
1999 : GTI : 1.8T : AGU : SPEC 1 R-TECH REMAP : BOSCH SUPER 4 : FORGE TIP : SILICONE TURBO HOSE KIT : 18" RS4 ALLOYS : -30MM ADJ SPAX SHOCKS/SPRINGS : FORGE 007P D/V (YELLOW) : MILLTEK CAT BACK RES 4MOTION : POWERFLEX DOG BONE BUSHES : PIPERCROSS FILTER : FORGE ACTUATOR (YELLOW) :
Offline Screech16v
  • MK3 20vt AGU
Re: Rear wiper doesnt work
« Reply #1 on: 09 February 2014, 15:27 »
Check where the wiring connects between the car and tailgate inside the rubber boot,its prob a broken wire
Offline Adam
« Reply #2 on: 09 February 2014, 17:08 »
Remove rear trim and check for water leaking from a rear water feed pipe.
Down Hill From Here.
Offline Rhyso
« Reply #3 on: 09 February 2014, 17:39 »
Plus the motor itself might have corroded as the pipe pops off, and the water then soaks the motor
Offline D4VEY01
« Reply #4 on: 13 February 2014, 22:08 »
Thanks for the replys,
Will check the wires and jet pipe tomorrow.
