Golf mk4
Wazzzer
turbo cooling
Topic: turbo cooling (Read 1165 times)
davidgtrr34
Here all the time
turbo cooling
08 February 2014, 16:24 »
is the ko3s turbo oil cooled or oil and water cooled.
if it has both does anyone no the best way to bypass the water pipe
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
rockmonkey69
Re: turbo cooling
08 February 2014, 16:30 »
Water and oil. What is it you intend to do? Not sure what you by bypass the water pipe? Do you mean to remove the water supply to the turbo entirely?
davidgtrr34
Here all the time
Re: turbo cooling
08 February 2014, 16:38 »
im going to be fitting a big turbo and it is only oil cooled and I wanted to completely remove the water pipes
rockmonkey69
Re: turbo cooling
08 February 2014, 16:47 »
That's fine, the water outlet can be capped off on the hard pipe that comes out next to the thermostat. Then just replace the banjo bolt for the water line from turbo to the block with a blanking plug with the same thread pitch.
davidgtrr34
Here all the time
Re: turbo cooling
08 February 2014, 16:53 »
thanks
Golf mk4
Wazzzer
turbo cooling
