Author Topic: key coding vagcom needed  (Read 1799 times)
Offline supramad77
« on: 08 February 2014, 14:30 »
Hi guys i need to have a second key coded as mine is falling apart. I have a key that is cut and tunned to my remote so it will lock/unlock the car. I now need to get the chip working. Went to a shop that tried but when he tried to put the 4digit pin in the car asked for 5 digits. He was afraid of messing up my only working key. Said i need to go to main dealer but they are reluctant to use my key and want £52 to try weather it works or not. So are there any vagcom places in the south west area i can go to?
Car is a 2.0 golf gti 115bhp 0n a 2000 plate W reg.
Thanks Pat
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: key coding vagcom needed
« Reply #1 on: 08 February 2014, 14:44 »
He needs to just put a 0 in front of the 4 digit code
Offline supramad77
« Reply #2 on: 08 February 2014, 19:27 »
Thanks for the tip will pass it on and see what he says.
Offline itavaltalainen
« Reply #3 on: 08 February 2014, 19:49 »
just look for someone with vcds in your area...
Offline supramad77
« Reply #4 on: 08 February 2014, 21:19 »
been trying to find a local guy but no luck yet. What is vcds?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 09 February 2014, 12:26 »
new name for VAG COM
Offline brianpologti
« Reply #6 on: 10 February 2014, 15:03 »
I thought u have to have vag tacho to do keys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 10 February 2014, 20:05 »
No you only need VAG TACHO to get the SKC if you don't already know it
Offline Loco-Gti
  • still driving
« Reply #8 on: 12 February 2014, 01:57 »
I thought that you could code your keys via the driver key barrel and the barrel....or am I mistaken
1.8t arz 5 door lc9z working on it slowly slowly. bora vents
« Reply #9 on: 12 February 2014, 08:59 »
No I think ur on about the fob part to unlock the doors etc , Not ignition part,
