Author Topic: vag com help  (Read 9655 times)
Offline wsmith
vag com help
« on: 06 February 2014, 16:19 »
ive just got the cable and software today off ebay ,ive set it as it says to. when i click on to scan my car my computer says the software has stopped working ,im running windows 7 on my laptop ?
Offline itavaltalainen
Re: vag com help
« Reply #1 on: 07 February 2014, 18:36 »
which cable did you buy, what laptop are you using, which version of windows 7, which version of vag com or vcds lite???
i am guessing cheap ebay cable, 64 bit windows, old 'internet download' version of vag com....
i'd try vcds lite... maybe it will work with that... if not then there's something that can be done but for that need an awful lot more info
Offline wsmith
Re: vag com help
« Reply #2 on: 07 February 2014, 20:10 »
i got the ebay cable and it came with software but i download of the main site vds lite it works but is asking for a licence number ,im just after the free software so do you have a link to the one i need ,im useing windows 7 home on a samsung r530
Offline noobmonkey
Re: vag com help
« Reply #3 on: 07 February 2014, 21:34 »
http://www.ross-tech.com/vcds/download/
The lite version should work fine. (Howver depending on the cable you have.... if it is a proper cable, the full version will work)
VW Golf MK7 GTD Manual 5DR Pure White
Re: vag com help
« Reply #4 on: 08 February 2014, 00:08 »
I don't know an 'ebay' brand cable... if it came with software why don't you use that, probably some cracked sh!t....
sorry to be blunt but why don't you put at least a link to cable here?
how am i to guess what cable that is?? there is so many out there. if you're lucky it's a genuine fdti chip.... if not it's fake and will only kinda work with the fake drivers it came with... if it's a prolific based chipset throw in bin... they never work - full stop....
Offline wsmith
Re: vag com help
« Reply #5 on: 08 February 2014, 05:32 »
hi sorry heres the link to the cable i got
 http://www.ebay.co.uk/itm/121224481017?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
if that one is crap which one is the best to get ??
Re: vag com help
« Reply #6 on: 08 February 2014, 09:58 »
The model you bought states that it won't work on Windows 7.
FDTI do a driver for Windows 7, with that VCDS lite (at least the unregistered test version) should work. If it doesn't this would suggest the Windows 7 driver does not work correctly. Whether this is installation issue or the hardware that came for 7.98 delivered I would not like to speculate ;)
Try to download drivers from here, then fiddle the COM settings (FIFO buffers etc)
http://www.ftdichip.com/FTDrivers.htm
maybe this will get it to work.
if not then it can be tricky to find a good one on amazon or ebay - most of them won't tell you which they are.
personally i use a serial version of the diagnostics adapter I built from a kit:
http://www.elv.de/elv-diagnose-adapter-fuer-obd-2-komplettbausatz.html
since my laptop does not have a rs232 com port I use this adapter (had it for µC projects etc - much better than many cheap converters out there which is why we use it at work too):
http://www.brainboxes.com/product/us-101/1-port-rs232-usb-to-serial-adapter
