Author Topic: Excessive white smoke  (Read 9571 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 02 February 2014, 16:12 »
Getting quite alot of white smoke at low revs in almost every gear...Especially when pulling off in 1/2nd. Once I get over like 2.5k revs it clears up. It is like this whhen cold or warm...
No Fault codes apart from P1256 - Coolant temp sensor open/short to ground (This is an intermittent problem, get the red STOP warning on the dash, but a re start re sets it...should I be worried about this?)
Any idea people?
My coolant level is good, not loosing any and I just topped up my oil, seems I'v been burning quite a bit since its service in June  :lipsrsealed:
Offline EsSeX dAn
Re: Excessive white smoke
« Reply #1 on: 03 February 2014, 12:25 »
could be the brass oil seals are starting to give up on the turbo, either that or the oil used last service is too thin so its serping past the seals.
as for you dash light, either try cleaning up the prongsin the header tank or replace the tank
i think i love you.....
Offline scarr89
« Reply #2 on: 03 February 2014, 21:01 »
That is what I have read else where...Any idea on how long this could last? I am planning a DSD upgrade...is this the excuse I need to do it sooner rather than later?
Offline EsSeX dAn
« Reply #3 on: 05 February 2014, 14:34 »
anytime. might break next time u start it, might last a year!
whats a dsd upgrade?
Offline scarr89
« Reply #4 on: 06 February 2014, 15:54 »
Darkside developments  :lipsrsealed:
Their turbo kits look so damn good!!!!!!!!!!!!
Offline EsSeX dAn
« Reply #5 on: 06 February 2014, 23:55 »
ahh yes. you kno this! my car would be an absolute weapon if i had 2.5k to loose on it!
Offline scarr89
« Reply #6 on: 07 February 2014, 10:56 »
Here in lies the issues...Come april I will have 2.8 to spend on it  :lipsrsealed:
So, I have done more reading, and it sounds like the turbo seals are going...I'll monitor the oil.
I also need a new clutch(well DMF), it has been awful for miles now!
So I'm thinking, 'budget' turbo kit, new clutch and a LSD?  :rolleyes:
I can get the clutch for cheaper and then fit my self, I guess fit the diff while I'm there...Hmmmmmmmmmmmmmmmm
Offline EsSeX dAn
« Reply #7 on: 08 February 2014, 20:51 »
after all of which youll probably get bored of it soon lol
also youll probsbly start thinking ok it goes well but doesnt stop as well as it could. hmmmm brakes.....
Offline scarr89
« Reply #8 on: 09 February 2014, 13:46 »
Don't worry, I am not that naieve. Will be getting some 256 rear and 4 pots.
Offline EsSeX dAn
« Reply #9 on: 09 February 2014, 21:20 »
there was no offence meant there! good brakes are always good lol im after getting uprated front and rear roll bars at the mo
