Author Topic: remapped 1.8t help  (Read 1424 times)
Offline wsmith
remapped 1.8t help
« on: 01 February 2014, 19:26 »
ive been having a bit trouble this week with my car first off i was traveling down the motorway at 70 over taking a wagon than when i just got past it my car died it was a bit strange it felt like there was no power so i put it in 4th than it took off as normal after a few seconds . i pulled over and it was running fine but for the past few days it feels like im driving a diffrent car between 1500-2000 revs its very hesitant and when its cold it soulds like its missfiring ,ive cleaned the maf and had it unpluged still the same, my cars had a recall on coil packs from vw new colder plugs in august ,serviced my 007p has anyone got any other things to check cheers
Offline navmk4gti
Re: remapped 1.8t help
« Reply #1 on: 01 February 2014, 19:28 »
Get it on vagcom and check for codes first
Offline wsmith
« Reply #2 on: 01 February 2014, 19:40 »
ive got a scanner and nothing comes up
Offline navmk4gti
« Reply #3 on: 01 February 2014, 20:00 »
Scanners are crap you need to use proper vagcom half codes i have through vagcom does not show on scanner i have.
Could be number of thigs,maf , coil packs, throttle body needing cleaning, etc
Offline wsmith
« Reply #4 on: 01 February 2014, 20:13 »
I just cleaned the TB the other day but I will order the cable for the laptop
Offline james18t
« Reply #5 on: 01 February 2014, 20:21 »
What kind of turbo intake pipe do you have? The stock ones are weaker and can suck flat under boost after a remap. Might be something to check..
Offline wsmith
« Reply #6 on: 01 February 2014, 20:27 »
I just have the original one on at the min
Offline rio_gti
« Reply #7 on: 03 February 2014, 12:56 »
n75 valve?
« Reply #8 on: 03 February 2014, 13:39 »
When I had issues with mine at low revs it was the Maf had failed.
Offline wsmith
« Reply #9 on: 04 February 2014, 17:50 »
cheers im just waiting for my vag com to get delivered to try that instead of the hand scanner just incase its missing codes off i will keep yous posted
