Author Topic: MK7 GT 2.0 TDI 150 Dyno results  (Read 59912 times)
Offline monkeyhanger
Re: MK7 GT 2.0 TDI 150 Dyno results
« Reply #50 on: 08 March 2014, 10:57 »
Am sure it's been covered but how easy is the box to fit ( for an incompetent moron like myself )
It is incredibly easy. There is a plug on the left of the common rail for the injection system, and a plug on the air filter housing for the turbo boost sensor. The wiring loom for the box has 2 ends on it. With the 2 aforementioned plugs undone, one end of each part of the loom plugs into the original VW plugs and the other end plugs into the VW sockets. It is a 2 minute job, maybe 5 mins, depending on how much thought and effort you put into redirecting the wiring loom so you don't need to cable tie it to existing looms. Just pop your bonnet, wait 5 mins to ensure the ECU is powered down (in reality, if you hang around the car after locking up, you will hear the electrics click off after around 90 seconds, 5 mins is an assurance that everything is off). You then pull the engine cover off, it is just held frictionally with 4 or 5 pegs, and do the unplugging and plugging.
The plugs themselves have locking tabs, you just need to hold these in while pulling the plug off its socket, for both sockets.
I will post a pic or 2 of the plugged in system later for you. All the plugs are easily accessible, like VW set it up for tuning!  :grin:
« Reply #51 on: 08 March 2014, 13:45 »
Excellent, thanks. Hopefully that's not beyond when when the time comes
Actually, you can see some pics I put in the "GTD+" thread when I gave a TDI-tuning box a go. The DTUK box plugs in the exact same way, there's arrows explaining what's what on the pictures. Towards the bottom of page 8 of the GTD+ thread.
http://www.golfgtiforum.co.uk/index.php?topic=260064.70
« Last Edit: 08 March 2014, 13:56 by monkeyhanger »
Offline Andrew@DTUK
« Reply #52 on: 09 March 2014, 08:12 »
Fitting instructions can be downloaded here :
https://db.tt/4mls56RH
Are you looking to tune your Golf GTI or GTD? Were currently offering members £80 off the full RRP on all DTUK Petrol and Diesel Tuning Systems.
PM me for the discount code
Offline p3asa
« Reply #53 on: 10 March 2014, 22:11 »
Andrew is the GTD dual channel CRDT-2 box the same as the Audi A1 2.0TDI box?
What I'm thinking is my A1 currently has a box with not a lot of gain so if its the same box as the GTD I could order one just now for the A1 and just transfer it to the GTD when it finally comes.
Or whats involved to make the change?
« Reply #54 on: 11 March 2014, 07:41 »
If the sets of plugs  on the 2 cars are the same (and they probably are) then the wiring loom will be the same, then it's just a case of getting a software update to replace the A1's maps for the GTDs maps when the time comes.
Offline Andrew@DTUK
« Reply #55 on: 11 March 2014, 12:05 »
First of all I'm surprised your not seeing any decent gains from your current system as these 2.0 143/170/177's respond very well indeed.
A DTUK CRD-T from an A1 can be transferred to the GTD but you would need 2 things.
1) software - this would be free of charge
2) new loom - 2 channel is £50 plus vat
« Reply #56 on: 11 March 2014, 12:23 »
Does the A1 CRDT stage 2 box (185PS from 143PS) not come with the same loom as the CRDT stage 2 box suitable for the GTD?
Offline Andrew@DTUK
« Reply #57 on: 11 March 2014, 13:45 »
The first generation of 1.6/2.0/2.7/3.0/4.2 VAG's come with a 3 pin common rail pressure sensor, and a 4 pin boost sensor. The latest 1.6/2.0tdi's have the same 3 pin common rail plug, but the boost sensor plug has changed to a 3 pin configuration.
If you were using a common rail box, then all you'd need is the software update
Offline p3asa
« Reply #58 on: 11 March 2014, 22:24 »
Its this box http://www.micro-chiptuning.de/Audi/A1/Chiptuning-Box-Audi-A1-20-TDI-105kW-143PS::1568.html and I'm very much of the opinion that you get what you pay for and this cost not a lot  :laugh:
Thanks for the info above. Like MH I would have thought they were the same.
Offline Daner
« Reply #59 on: 14 March 2014, 11:19 »
I am looking into buying a Mk7 Variant 4Motion here in Sweden, so the promise of uncorking some additional power is tempting indeed. The 2-channel box seems most promising, but I would also like to find a good description of any mechanical differences between the factory 150hp and 184hp versions of the 2.0l EA288. Is it all mapping, or are there other bits that might be worth looking into to optimize the ratio of performance vs. reliability?
