Author Topic: Locking wheel nut removal for dummies.  (Read 3033 times)
Offline Bellend
« on: 30 January 2014, 00:13 »
This takes approx 30 seconds and you can do the but back up as per normal.
Just need an M16 spline tool, hammer and a breaker bar.
Line it up and tap it in. Needs next to no force! Could probably do it with a rubber mallet it's that easy!
In perfect condition!
Most probably wouldn't even need the idea but I'm sure someone will ask one day. :whistle:
Where all my moneys went.
Offline Tezmax
Re: Locking wheel nut removal for dummies.
« Reply #1 on: 30 January 2014, 18:17 »
Not bad......but i've got the solid head wheel nuts :laugh:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline davidgtrr34
« Reply #2 on: 30 January 2014, 18:26 »
the solid ones are even easier. just get a socket that is a bit smaller and beat it on and TADA it will come off :smiley:
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
VW BUSH
« Reply #3 on: 30 January 2014, 19:17 »
The universal Sligo socket :grin:
Best if you (can) use an impact socket, the don't split as easy
Offline james2
  • No scammers please.
« Reply #4 on: 30 January 2014, 20:09 »
lol, this is a pikie way of removing locking nuts.  :evil: way not use the locking nut key/socket  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline navmk4gti
« Reply #5 on: 31 January 2014, 12:26 »
Im sure the op suggested this method if you have lost your locking nut key
Offline Bellend
« Reply #6 on: 31 January 2014, 12:40 »
:grin:
It slides in and out so easy after you've tapped it in once that I just bought a spare and chucked it in the glovebox.
