Author Topic: Mk4 golf 1.8t turbo problem  (Read 1691 times)
Offline Micksabs89
« on: 29 January 2014, 22:51 »
Hi bought a mk4 golf 1.8t for cheep the lad said it didn't run properly but was cheep enuf and very clean the problem is it just doesn't seem like the turbo is coming in at all and haven't really got a clue what to do next tried a few things but still nothing has any one got any ideas thanks
Offline xionsolaris
Re: Mk4 golf 1.8t turbo problem
« Reply #1 on: 29 January 2014, 23:41 »
Check the boost pipes for any leaks. When u rev the engine do you hear any hissing noises
Offline dom
  • Back in a Mk4
« Reply #2 on: 30 January 2014, 07:20 »
Get it scanned for fault codes.
Offline joshstanvw
« Reply #3 on: 30 January 2014, 12:06 »
As Dom says get it scanned it could be one of a few problems ranging from a blown turbo to a boost leak just out of interest what year is it
Also does it seem to drive ok ie running sweet just no turbo
GTI is not a trim level. It is a lifestyle.
1999 1.8t AGU, KO3s, forge 007p, silicone tip and charge pipe, oil catch can, SS turbo back system, pipercross CAI, g60/vr6 clutch, 40mm apex springs, drilled and grooved discs, stage 2 remap.
Offline rio_gti
« Reply #4 on: 30 January 2014, 13:16 »
maybe you got sold a 1.8 n/a  :laugh:
Offline joshstanvw
« Reply #5 on: 30 January 2014, 13:42 »
That would just be sacrilege.
"Here you go mate one golf gti but something is wrong with the turbo"
Then he walks away muttering "what's wrong is it never had a turbo"
I know a few dealers like that!!
Offline Micksabs89
« Reply #6 on: 30 January 2014, 16:30 »
Hi it is a 2000 runs mint just no turbo and checked pipes no splits
Offline Micksabs89
« Reply #7 on: 30 January 2014, 16:34 »
Also carnt get computer to connect to car I was using snap on ethos I don't know why someone did mention a aftermarket radio could stop it but don't know if this is true
Offline dom
  • Back in a Mk4
« Reply #8 on: 30 January 2014, 16:36 »
If you've got an aftermarket headunit then you need to check that there is nothing connected to the k-line. Take the headunit out look at the lower iso block, there should be nothing connected to the grey and white wire that is part of the factory wiring.
You need to get it scanned really as it could be any number of things wrong.
Offline Micksabs89
« Reply #9 on: 30 January 2014, 16:38 »
I will take the radio out now and have a check is there anything else what could stop it connecting
