Author Topic: Transponder programming-can it be done via these machines?  (Read 2521 times)
Offline Jasikasisback
I recently misplaced my only key to my Golf and am in the process of getting a new key from the dealer.
They hinted that I take a look online about possible ways of linking the key to the car that would be cheaper than the £30 pounds the dealer charges.
These two machines were mentioned..
http://www.ebay.co.uk/itm/Nw-Opel-Immo-AirBag-Scanner-Cable-Vag-Tacho-3-01-for-OPEL-IMMO-1-IMMO-2-Polo-/261310250187?pt=UK_Diagnostic_Tools_Equipment&hash=item3cd74dfccb#shpCntId
and
http://www.ebay.co.uk/itm/VAG-K-CAN-Commander-Full-1-4-Diagnostic-Scanner-Audi-VW-Skoda-Seat-OBD2-EOBD-UK-/171126308960?pt=UK_Diagnostic_Tools_Equipment&hash=item27d7ec4060
I am not familiar with either of these machines as I only have a U281.
If anyone has any experience with either of the two machines above can they tell me if you can programme a key with a transponder to your car without having to rely on dealer assistance and how I would go about doing that-a sort of step by step guide.
The VW dealer near me the parts gentleman is sort of hinting that these methods work and I should look into them. If not I can get the key programmed through the dealer for £30.
Any help would be appreciated as I would buy one of the units above and then use it to link my key to my car if possible. I will then have the technology to do this for anyone else who may need it.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Transponder programming-can it be done via these machines?
« Reply #1 on: 29 January 2014, 19:48 »
What mk Golf exactly?
Offline itavaltalainen
« Reply #2 on: 29 January 2014, 20:36 »
he's got a mk3.
the second one is clearly out, mk4 is the earliest it can do.
the first not 100% sure but don't think vag tacho can do anything on mk3, since the immobiliser is not in dash...
as i've said, if you come to malvern i can do it for you.
VW will give you the 7 digit code if you tell them the immobiliser ID code (this can be read with vcds - even a demo version).
all you need is this code (plus dealer id and date) and obviously a new key with the rfid chip inside. see ***
if you're a bit flexible i might be able to meet you somewhere after one of my jobs at a services (travel all over midlands for work every day)
 Write down the 14 digit Immobilizer ID number (from diagnostics; this would normally be something like VWVZ3Z0Txxxxxxx)
 Take that ID number to your dealer and request your seven-digit SKC, along with the workshop code and importer number and the date it was retrieved by the dealer (all this information can be found in the upper-right corner of the Administration screen of the dealer's VAS 5051).
« Last Edit: 29 January 2014, 21:32 by itavaltalainen »
« Reply #3 on: 29 January 2014, 21:43 »
Thanks for the offer, I will definitely take you up on it at some point in the future.
I think I will just get the key programmed by the dealer and leave it at that. They said that two keys will cost me £75 or one will cost £55 and that they will programme one or two keys at the same time, so no extra cost for programming the second key. The other key will turn up eventually but I think it will no longer work once they link the new keys to the car.
Lesson learned-never leave your keys where your kids can get to them..:)
« Reply #4 on: 29 January 2014, 21:52 »
when you go to vw ask them to give you a printout with the 7 digit code and other stuff, then you can recode the other key when it turns up again. :)
mk3 keys can be reprogrammed indefinite number of times.
shame you can't get key made from lock
