Author Topic: Vibe  (Read 2126 times)
Offline Mcwill
Vibe
« on: 29 January 2014, 12:49 »
Hi guys got an annoying vibration on clutch and accelerator pedal on my abf.
It's starts around 2500rpm, I'm thinking engine mounts what do you guys rec?
Offline Sam
  • Sam I am
Re: Vibe
« Reply #1 on: 30 January 2014, 11:17 »
Chances are (unless your clutch is heading south, test this by heading up hill in a higher gear than usual and flooring it, if your revs go up quicker than you would expect it is) that it's the rear engine mount that slots into the subframe if you are thinking engine mounts rather than CV joints, bearings etc.
You need to undo the bolt going through it, jack the engine up and unbolt the three(ish) bolts on the passenger side subframe. Stick a crow/pry bar between the chassis and sub and pry the sub downwards, this should allow enough space to get the bushing out. Oh and most recommend upgrading to the MK3 solid mount.
Cheers, Sam
Offline weazgti
Re: Vibe
« Reply #2 on: 30 January 2014, 12:02 »
Sounds daft but I had the lower dash tray vibrating through pedals on mine because the bottom wasn't clipped on near tge pedals
Offline Mcwill
Re: Vibe
« Reply #3 on: 30 January 2014, 17:00 »
Thanks guys will check both.
Offline Gambit
Re: Vibe
« Reply #4 on: 30 January 2014, 17:38 »
have a look at the gearbox support bracket, if the 2 bolts are put in with the nut side against the chassis leg they can sometimes foul on chassis leg & cause the vibration
Offline Sam
  • Sam I am
Re: Vibe
« Reply #5 on: 17 February 2014, 11:55 »
Any luck boss?
Offline Mcwill
Re: Vibe
« Reply #6 on: 17 February 2014, 12:42 »
No took it down to the garage and they couldn't find anything wrong  :undecided:
