Author Topic: High Beam Assist - Sensitivity  (Read 16829 times)
Offline kevinm
Re: High Beam Assist - Sensitivity
« Reply #20 on: 30 January 2014, 10:42 »
My lights react faster than I could myself but I have the dynamic light assist.
I stumbled upon the option to change the light intensity to change from high to low beam. I can't remember if it was in the central electrics or front camera. The unit was lux. I'll check it tomorrow.
This looks interesting :) When you say camera, do you mean the High Beam Assist module [20]?
I mean the camera above the mirror. Ill check this evening.
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 10000015927
   Coding: 0100020001020303000400000100010100
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A70C995BDA2F9CE9A7-806F
No fault code found.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline jivemonkey
« Reply #21 on: 30 January 2014, 10:44 »
By gosh you're right! I wonder how long that's been sitting there..seems odd that they've created a new name for it, I thought it was DLA (dynamic light assist)?? Dynamic high beam assist is certainly sounding different to plain old high beam assist. Why would it only come with lane assist I wonder? Is there anything else apart from the shutters in the headlamp units that would be needing changed for lane assist?  :huh:
As long as it's not the new factory standard, I'm happy!  :tongue:
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline jivemonkey
« Reply #22 on: 30 January 2014, 10:47 »
You must have the different camera for lane assist? I don't have what you're showing..only the [20] high beam assist I mentioned..
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Offline kevinm
« Reply #23 on: 30 January 2014, 11:18 »
This is what the a5 camera looks like:
I don't have module 20. The same camera does DLA and lane assist. You can spec lane and regular high beam assist in Ireland. Lane and dynamic light assist costs a bit more, probably to cover the headlights with extra shutters.
It wouldn't be the first time vw uk renamed an option. The renamed comfort as advanced bluetooth. And to be fair dynamic high beam assist is a better description of it.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline kevinm
« Reply #24 on: 30 January 2014, 22:02 »
The setting is in the A5 camera module. Maybe something similar is in your high beam assist module.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline jivemonkey
« Reply #25 on: 31 January 2014, 10:20 »
Will check the high beam assist module and see , but fairly sure there's not that much in there.
Had a quick look and looks like the UK can't spec Lane Assist at all, it's not an option on the configurator and not an option when speccing the car up on various broker sites (which are usually quite accurate).
