Author Topic: High Beam Assist - Sensitivity  (Read 18604 times)
Offline mrluketee
Re: High Beam Assist - Sensitivity
« Reply #10 on: 29 January 2014, 21:26 »
Interesting angle, but I'm with the OP on this. The description on the VW website certainly suggests it is indeed a driver assistant, but more in respect of doing it for you and 'making it safer' by removing the requirement to keep 'constantly switching from high to dipped beam'.
http://www.volkswagen.co.uk/technology/comfort-and-convenience/high-beam-assist
If it was only intended to be a 'back up' system in case you forgot, then wouldn''t it always be enabled and only turn the main beam off, and not back on? Plus, I'm sure if you toggle the main beam a few times you actually disable the High Beam Assist entirely. Could be wrong there though.
Back to the OP, I also think it's a little slow, only a second or so, but could certainly be a little quicker. Don't use it much anyway as my route is well lit.
Thanks Jive, if that's how VW advertise it then fair enough, I wouldn't expect to have to toggle back and forth either!
Standard GTD 3dr
Offline itavaltalainen
« Reply #11 on: 29 January 2014, 21:36 »
Works pretty reliable on my estate. Mind you that it also has cornering lights, so in a corner it tends to anyway point the lights just off the centre to the left anyway, so it would not blind oncoming drivers in turns that badly.
On straights it works 100%...
I'm not sure you're referring to the same thing - high beam assist doesn't operate beneath 40 odd MPH and will only operate in complete darkness - any street lighting and it'll keep dipped beam.
yeah i'm on about the high beam assist... ;)
Offline 2014GTi
  • Das Auto
« Reply #12 on: 29 January 2014, 21:38 »
I can't say that I've had any issues with mine, works so far  :smiley:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline kevinm
« Reply #13 on: 29 January 2014, 22:44 »
My lights react faster than I could myself but I have the dynamic light assist.
I stumbled upon the option to change the light intensity to change from high to low beam. I can't remember if it was in the central electrics or front camera. The unit was lux. I'll check it tomorrow.
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
« Reply #14 on: 29 January 2014, 22:59 »
you get DYNAMIC light assist in ireland?  :shocked:
why do the buggers not sell it in uk (same for reversing cam)  :undecided:
Offline kevinm
« Reply #15 on: 30 January 2014, 09:33 »
Ya it was on the price list but nobody had ordered it here before so there was a lot of hassle adding it to the spec.
First VW ireland said it can only be ordered with halogens but after I sent them the German price list that said only WITH xenons they asked the factory and there is a different option code for xenons with dynamic light assist.
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline kevinm
« Reply #16 on: 30 January 2014, 09:37 »
I just noticed Dynamic Light Assist is now on the UK price list!
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline jivemonkey
« Reply #17 on: 30 January 2014, 09:39 »
What?! It better not be... :angry:
edit: nope - still absent!
« Last Edit: 30 January 2014, 09:45 by jivemonkey »
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline jivemonkey
« Reply #18 on: 30 January 2014, 10:22 »
This looks interesting :) When you say camera, do you mean the High Beam Assist module [20]?
Offline kevinm
« Reply #19 on: 30 January 2014, 10:29 »
It is! It's bundled with lane assist.
EDIT:
« Last Edit: 30 January 2014, 10:34 by kevinm »
Previous:
2014 GTI PP DSG
GTI ED30 DSG
