Golf mk3
hardmonkeys
Sunroof drain pipes
Topic: Sunroof drain pipes (Read 2091 times)
Blazeman1995
Sunroof drain pipes
26 January 2014, 16:04 »
I'm trying to sort out the leaking of my sunroof and have discovered that the pipe has disconnected where it exits at the door. i was wondering if anyone knows how to get access to reconnect the pipe without having to pull out the dash.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Sunroof drain pipes
26 January 2014, 19:46 »
you should be able to get to it by taking off trim from a pillar and some trim from footwells (fuse box cover / lower glove box part depending on o/s or n/s).
Blazeman1995
26 January 2014, 21:15 »
its on both sides and i can only get enough access for one hand
itavaltalainen
26 January 2014, 21:38 »
one hand can do plenty
Golf mk3
hardmonkeys
Sunroof drain pipes
