Golf mk7
Jimble
Coolant Loss
Topic: Coolant Loss (Read 2335 times)
Chief1337
Here all the time
Coolant Loss
26 January 2014, 14:47 »
Hi All,
I've done around 2000 Miles in the GTi now and absolutely loving it. I have noticed however, a small (1 'star/lines' worth) of coolant loss. Is this usual? Have topped up with some G12++.
Regards,
Chief
mk7gti
Re: Coolant Loss
26 January 2014, 17:33 »
My coolant level seems to vary quite a bit based on temp and its currently sitting at the low level. My Scirocco used to do the same thing and was normally topped up at each service...
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: Coolant Loss
26 January 2014, 20:33 »
normal for new car... there is always a tiny amount of air left in the system, over time this finds it way into the expansion tank....
nothing to worry about.... 100% of cars i've seen when i worked at europcar a few years ago had this 'issue'....
g12++ is not really for mk7 golfs anymore officially, now it's called g13.... small amount won't make any difference though since they are mixable...
RedHP
Re: Coolant Loss
26 January 2014, 22:03 »
Keep an eye on it as water-pump issue was common with new Mk6 GiT's. Mine had to replaced within a year under warranty
Red
Mk6 GiT since birth in 2010
YNWA
Golf mk7
Jimble
Coolant Loss
