Author Topic: mk3 vr6 front wheel caster setting  (Read 3426 times)
Offline Outlawsaffa1982
« on: 26 January 2014, 05:47 »
Morning all, took the vr to quick fit to have the wheel alignment done, tracking was done and camber was fine, but i was told that the caster was out and they didnt have the settings on there data base to adjust it back. Does anyone know what it should be or where i may find the info needed?
Offline chris_d66
  • Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
Re: mk3 vr6 front wheel caster setting
« Reply #1 on: 26 January 2014, 09:52 »
As far as I know the caster angle is not adjustable measure the distance between the front and rear hub nuts both sides to see if there is any difference,
You could have worn top strut mounts, bottom arm mounts or crash damage. But if the Golf is lowered and the distance is the same the cast angle wouldn't of changed but the distances between front and rear would be shorter than at standard height.
Caster +1o45' +/- 30' +1o50' +/- 30' (degrees) these measurements are taken from a reference book which all garages should have and it will say that adjustment is not possible
If your Golf drives ok, doesn't scrub the tyres, stable at high speeds and the distance is the same with no sign of crash damage I wouldn't worry about it.
New toy1990 Scirocco I feel a 16v conversion coming on.
Offline tweed
« Reply #2 on: 26 January 2014, 13:41 »
Pretty sure you can adjust caster by the subframe.
Offline chris_d66
« Reply #3 on: 26 January 2014, 14:06 »
I thought sub frame realignment only affected camber
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #4 on: 26 January 2014, 21:46 »
From what ive read and admittedly how much of is true I don't know there is a small amount of castor adjustability on the subframe locating mounts.
« Reply #5 on: 27 January 2014, 03:33 »
Thanks for the info guys, there is no crash damage and yes the car is lowered but both side are at the same height... the car is stable at speed the only thing is it vibrates badly at the moment, and thats after having the alignment done...
Offline tweed
« Reply #6 on: 27 January 2014, 07:55 »
Vibrates afyer 60mph?
A weight could of been removed/knocked off. Best to get ya wheels balanced
« Reply #7 on: 27 January 2014, 07:59 »
It tends to settle down after 60/75 but will pick up again at around 90... It's bloody strange! I have never had trouble with it before!
Offline Bellend
« Reply #8 on: 27 January 2014, 10:24 »
Balancing, tyres, driveshafts, wheel bearings.
All can cause it.
Where all my moneys went.
