Author Topic: Brrrrrrrrrrrrrr  (Read 1100 times)
Offline Redbaron
Brrrrrrrrrrrrrr
« on: 28 August 2005, 23:15 »
Its cold in my golf.
When i put the heater slide to hot i get hot air for a bit, then it goes cold after a short while.
If i put it back to cold again for a few minutes then slide it over to hot again the same thing happens.
Why is this? I need hot air, esp for the winter!
(mk2 golf gti 16v)
Offline Rain
  • forum irregular
Re: Brrrrrrrrrrrrrr
« Reply #1 on: 29 August 2005, 18:57 »
sounds like the water isnt circulating properly there should be 2 valves maybe ones blocked or had it. you can spot under the bonnet as there the only pipes going into the bulkhead of the car there are 2 valves and 1 small pipe that goes between them.
Offline the.little.fox
Re: Brrrrrrrrrrrrrr
« Reply #2 on: 29 August 2005, 21:24 »
Can't help I'm afraid mate, but I can sympathise.
The heater matrix in my last golf didn't work the whole time I had it.... a year and a half! 2 winters.
It got so cold in there that the windscreen froze on the inside every morning.
It was harsh and gross, coz it used to get so condensated (and very occasionally I resorted to anti-freeze!)
Hope you get it sorted, I'm sure you will, surely there can't be anyone out there who would put up with it for as long as me???
x
Offline Rain
  • forum irregular
Re: Brrrrrrrrrrrrrr
« Reply #3 on: 29 August 2005, 21:58 »
lol how you went 2 years without a heater i have no clue id go mad if i didnt have heat :S its not hard to change the valves or the matrix can seem a nightmare but its actually really simple can be done in a few hours.
Judderi
Re: Brrrrrrrrrrrrrr
« Reply #4 on: 30 August 2005, 11:50 »
Have you checked your coolant level? Maybe there just insnt enough water to circulate properly. Or try flushing the whole system to clear any gunk in the pipes.
