Golf mk4
Wazzzer
compression test
Topic: compression test (Read 1540 times)
davidgtrr34
Here all the time
compression test
25 January 2014, 15:22 »
I have no power and a knocking noise. the noise gets louder when I rev it and stops when I let off the throttle.
I done a compression test and these are the results
cylinder 1 - 35psi
cylinder 2 - 30psi
cylinder 3 - 30psi
cylinder 4 - 30psi
the car still starts and runs.
can anyone help?
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
maxey
Re: compression test
25 January 2014, 19:12 »
I have the same problem mate, does it shack like mad?
davidgtrr34
Here all the time
25 January 2014, 19:25 »
Not really.but im gettin alot of fault codes and no boost
rockmonkey69
26 January 2014, 11:05 »
Those figures seem a tad low, very low. I'm surprised the engine is even running. Looks like its time for a rebuild, new engine or new car
xxChrisxx
GTI forum regular
26 January 2014, 11:23 »
Those values are too low to be real. I'd try doing again with a different gauge.
Working order is approx 12.5 bar.
Wear limit is 7 bar.
For anything to be massively below that the timing has to be out, allowing one of the valves to be open.
davidgtrr34
Here all the time
26 January 2014, 13:19 »
Ill test again with a different kit. The timing seems to be fine
Wayne
Sir Postalot
Reply #6 on:
26 January 2014, 20:49 »
I would get another gauge and try again
Golf mk4
Wazzzer
compression test
