Author Topic: Angle of wheel on full lock?  (Read 3131 times)
Offline Carl!
« on: 25 January 2014, 09:10 »
Does this look right?! if it doesnt can anyone diagnose just from the picture?! I get a dodgy noise whenever I have to turn that direction when setting off also.
Offline Nino
Re: Angle of wheel on full lock?
« Reply #1 on: 25 January 2014, 09:42 »
It is normal for it to angle but i dont think it should angle that much however i cannot be certain.
If it is wrong then ether your track rod arm or wishbone arm will need changing.
You say that you hear a noise when turning, that will be your power steering pump struggling, happened to mine, check your power steering fluid, is it at a safe level?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Carl!
« Reply #2 on: 25 January 2014, 11:19 »
cheers fella, I dont think its the power steering because its only when turning right and at a certain degree, no other time. ive recently changed track rod ends so I'll look into wishbones,  do the bushes go on them or is it best to just go for complete replacement?
Offline Nino
« Reply #3 on: 25 January 2014, 11:34 »
yes the bushes do go, its worth replacing the whole lot for the price it costs mate
Offline dom
  • Back in a Mk4
« Reply #4 on: 25 January 2014, 13:22 »
You running a standard ARB? You're about the height that would cause it to rub on the driveshaft when turning right.
Offline Carl!
« Reply #5 on: 25 January 2014, 15:00 »
yes dom I am! ive got to raise it for remap Wednesday so I'll see if the noise goes, that is the kind of noise id imagine that would make as well!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 25 January 2014, 16:53 »
You'll have witness marks on the driveshaft if it has been rubbing
Offline Carl!
« Reply #7 on: 27 January 2014, 18:19 »
Dom you were right it was the driveshaft rubbing. Looks like i'll have to keep an eye out for a uprated arb.
Offline dom
  • Back in a Mk4
« Reply #8 on: 27 January 2014, 19:40 »
Easily resolved then :afro:
Offline Carl!
« Reply #9 on: 27 January 2014, 21:02 »
yeah, glad it's nothing major.
