Author Topic: 16v will not start please help  (Read 1432 times)
Offline sd
« on: 28 August 2005, 20:49 »
:sad:
Hi all my 1988 16v will not start.
The car was a OK, and then i turned the key it would  not turn over I put the light on and turned  the key and  they dimmed.
The battery is OK I think because if I put some jumpleads on it, it still will not start. If I push start the car it will fire up and run OK. I  think it is the start  but I have not had any trouble with it sticking.
Please help
Offline rowlers
  • I'm back - MK7 GTI
Re: 16v will not start please help
« Reply #1 on: 28 August 2005, 21:08 »
what happens when you turn it over? does it try to fire or just turn over - quickly/slowly??
If it starts with a push I would assume it can't be anything major.
Have you checked anything out so far?
Does it smell of petrol when you try to turn - i.e is it flooded?
Sorry can't offer more solutions, the guys on here will need more info first!!
Offline sd
« Reply #2 on: 28 August 2005, 21:12 »
when i try to turn the key there is a clicking sound and the engine does not turn over.  the engine does not smell of fuel i have tried hitting the starter motor but it still will not turn over.
Offline Mr Blue
« Reply #3 on: 28 August 2005, 21:19 »
i would say thats the starter motor solenoid thats being gay
mine use to do this. Try turning it over then wait for a minute or 2 and see if it fires up.
My motor also caught fire after a few months with the problem
« Last Edit: 28 August 2005, 21:22 by Blue Mk2 »
Offline Redbaron
« Reply #4 on: 28 August 2005, 23:00 »
Im willing to bet money your battery is fecked.
I had exactly the same problem, tried charging it and everything, would just click rapidly.
put on a different battery, problem solved.
try it.
Offline mjamoose
  • I'm off a hunting! (for a head gasket)
« Reply #5 on: 29 August 2005, 23:46 »
Same problem here! Solution is to buy a new battery.  When I bought the car in march this year it had the original battery!
I suppose it's forgivable considering the age of the car...
WARNING DRUMMER ON THE LOOSE :evil:
Judderi
« Reply #6 on: 30 August 2005, 11:46 »
Yeah the starter motor will just click merrily if it cant get enough power from tlhe battery.
Offline Agreeable Slick
  • Unit
« Reply #7 on: 30 August 2005, 11:53 »
does the fuel pump prime?
IS there a spark getting to the plugs?
Does the motor actually continually click or just once?
