Author Topic: BAD STARTER  (Read 1162 times)
Offline DUNNY
BAD STARTER
« on: 28 August 2005, 19:01 »
HELLO ALL  HOPE YOU CAN HELP IV'E GOT A 8V 2E GOLF AND HAS JUST STARTED TO BE A BIT OF A BUGGER TO START I JUST KEEP CRANKING FOR ABOUT 15 SECONDS THEN IT STARTS WERE AS BEFORE IT WOULD FIRE UP WITH JUST TOUCHING THE KEY  WHEN IT DOES START THE IS BLACK SMOKE FROM THE BACK AND IT STINKS OF PETROL HOPE YOU CAN SORT THIS FOR ME AS MISSUS IS PI**ED OFF WITH ME BEING CHOPPSEY THANKS  : :embarassed:
Offline DUNNY
Re: BAD STARTER
« Reply #1 on: 29 August 2005, 17:34 »
HI FORGOT TO MENTION IT STARTS FINE IN THE MORNING BUT ONCE ITS BEEN DRIVEN BECOMES A REAL PIG TO GET GOING AGAIN. NO 30 RELAY GETS WARM BUT NOT HOT IVE CLEANED THE THROTTLE BODY DIZZY SPARK PLUGS PUT INJECTOR CLEANER IN BUT STILL NO BETTER PLEASE HELP :cry:
Offline DUNNY
Re: BAD STARTER
« Reply #2 on: 31 August 2005, 12:41 »
 :angry:HI ALL AS NO ONE SEEMS TO KNOW THE ANSWER I HAD TO DIG DEEP IN THE SKYROCKET AND GET IT SORTED BUY SOME ONE WHO DOES THE PROBLEM TURNED OUT TO BE COOLANT TEMP SENDER SO NOW IS RUNNING SEET AS A SWEET THING GETS HOPE THIS HELPS OTHER POEPLE OUT  :laugh: :laugh:
