Author Topic: Dynamic cornering not working?  (Read 3757 times)
Offline Mk1Macca
« on: 22 January 2014, 21:38 »
I've noticed that the lights that aim to the side in the headlights don't seem to be working.
I've looked in the settings page and turned them off and back on again (technical trick), but to no avail. When I demo'd the GTD, they functioned while stationary (which makes it easier to see if they're on), but should they? Are they actually working, but I can't see it when stationary as they don't function?
Offline noobmonkey
Re: Dynamic cornering not working?
« Reply #1 on: 22 January 2014, 21:39 »
when stationary, that is the static lights, not the dynamic cornering ones :)
(As far as i am aware)
VW Golf MK7 GTD Manual 5DR Pure White
Offline Mk1Macca
« Reply #2 on: 22 January 2014, 21:42 »
Sorry, you're right, that's what I meant. Those side aiming lights don't appear to be functioning :(
Offline noobmonkey
« Reply #3 on: 22 January 2014, 21:44 »
hmmmm, well i'm pretty sure there is a limit to the speeds they work, but easily visible in the dark...
Interested to find out a bit more about them etc though - might go do some digging.
Offline GTI-7-Performance
« Reply #4 on: 22 January 2014, 21:46 »
The Dynamic cornering (not the fog lights coming on at each side) only work above 60kph/40mph. You can set these in the central computer thing to Sport, normal or off...
Offline KyleB
« Reply #5 on: 22 January 2014, 21:57 »
Its worth noting they don't come on if you've got Eco mode selected I believe.
Offline Mk1Macca
« Reply #6 on: 22 January 2014, 22:02 »
That IS worth noting. The car is currently in eco.
Stand by for a quick run outside in my jammies to check...
Offline double0
« Reply #7 on: 22 January 2014, 22:09 »
Easy way to check if the lights themselves are working is to stick it in reverse as for some reason VW have decided to enable reversing lights on the front!
Offline Mk1Macca
« Reply #8 on: 22 January 2014, 22:09 »
Problem solved :)
To clarify, the low speed side lights will NOT come on in Eco mode.
Thanks Kyle!
Offline C2K
  • Northern Monkey
« Reply #9 on: 22 January 2014, 22:34 »
Search function!  :smiley:
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
