Author Topic: Lost your keys?-Got quoted £25 the first time but £75 the second by VW dealer.:(  (Read 4345 times)
Offline Jasikasisback
Not sure if you guys knew this or not, but will pass on this information as I have misplaced my key at home somewhere and cannot find it. VW dealership charges £25 for a new key and that will be made in a maximum of 10 days. I think that is quite reasonable considering new keys cost much more.
This is cheaper than the Timpsons near me so this is one case where the dealer is cheaper than others.
I read through the posts here and people mentioned higher costs so thought I would pass that along.
FYI.
« Last Edit: 21 January 2014, 15:45 by Jasikasisback »
Offline itavaltalainen
Re: Lost your keys?-Only £25 to get them made a VW dealership.
« Reply #1 on: 21 January 2014, 14:11 »
Which key is this? Just the standard one?
If your car has immobilizer don't forget it may need recoding.
Still quite a good price.
Nothing compared to how much a keyless one for my mk7 would be....
Offline gasketface
« Reply #2 on: 21 January 2014, 14:55 »
I think you'll find that the price is for key only.To program it is around £75 from VW.I do'nt think a VW dealer will ever be cheaper than someone else unless they are having a clearout or are going bust lol.
Timpsons say :-
Our original keys are exactly the same as the car dealer has, the big benefit having Timpson do your keys is they are on average 20% cheaper and can offer a more efficient programming service than the dealer.
« Reply #3 on: 21 January 2014, 15:43 »
Called them again and yes this time they said it would cost £75 for a replacement key. It no longer takes 7-10 days and they would do it right there and then...so sorry for the misinformation as I was misinformed when I first called them. Bummer...I will turn everything upside down in my flat and try to find my key...
Ok I have not found my keys and will give up after tomorrow and bite the bullet. If anyone knows of a service that will do it cheaper than the dealer then please post. The dealer near me wants £75 and will do it in a day (at least that is what they said over the phone the second time)
Offline Ninja
  • 19 smiles per gallon
Argue the point you were told £25 - that's not on. Typical vw
I phoned again and got quoted £25 for the key and £30 to get it programmed.
It will be an expensive lesson for me misplacing this key, which will become a door key if I ever happen to find it.
I was hoping someone on here would be able to do it all for cheaper...guess that is a niche that someone on here can get into if it is profitable.
Was looking to see if a early ECU along with changing the locks and ignition barrel would be cheaper but a couple of people who are breaking cars want more than it costs to get the key from the dealer.
If anyone knows of a private locksmith who can do it cheaper please post on here.
if you have the login code for the ecu (it's on a small black tag that came with the keys) then someone with vcds can program the key for you (literally a 5min job).... then all you need to get is the key (obviously get it cut).
unfortunately i dont have this..i'd appreciate it if you could take a picture so when buying in the future i will know what it looks like.:). I'd wish it was written in the service schedule that came with the car. I'll just get the key done next week. I've looked for the key for 6 days now and no luck..
