Author Topic: Help needed HIGH BEAM ASSIST  (Read 6026 times)
Offline chazzypuk
« on: 20 January 2014, 17:43 »
Hi,
I have just received my new car and I specced high beam assist. I don't think it has been added as I have no option to turn it on in the car settings and when I go main beam it doesn't have the "A" next to the main beam symbol. Should it be like this? Should there be an option?
Thanks,
Golf GTD Mk7 3dr Manual, Pure White, Adaptive Chassis Control, Panoramic roof, Discover Pro Nav, Keyless entry, Dynaudio, Park assist, High beam assist, Leather pack, Service Pack.
Offline peterdoherty
Re: Help needed HIGH BEAM ASSIST
« Reply #1 on: 20 January 2014, 17:46 »
You turn it on by pressing the stalk away from you once whilst the lights are on - on the display (at the bottom) you should see a small high beam symbol with an A to indicate high beam is in auto mode.
Also there will be a small camera on the back of the rear view mirror
MKVII GTD DSG Carbon Grey 5DR, Dynaudio, Keyless Entry, Rear View Camera, Colour MFD, Park Assist, Winter Pack, Climate Screen, Advanced Phone Kit, High Beam Assist
Offline monsta
« Reply #2 on: 20 January 2014, 17:56 »
Re: camera
Have a look for something like this;
Offline chazzypuk
« Reply #3 on: 20 January 2014, 18:42 »
Thanks for your replies guys. I have been out again and it does appear to work! I do have the camera on the mirror. I do feel a little stupid now!  :shocked:
One question though. Should you be able to turn it on and off in the car lighting menu? The manual says you should.
Offline Mark V GTD
« Reply #4 on: 21 January 2014, 00:20 »
As reported in post 2 - its turned off and on by use of the left stalk....
Offline chazzypuk
« Reply #5 on: 21 January 2014, 00:35 »
Yeah I understand that now. The manual says otherwise stating it can be done through the car setup on the touchscreen. This seems to be incorrect. The guy at the dealership didn't even know how it worked!
Offline iandjm
« Reply #6 on: 21 January 2014, 10:12 »
Hey,
Were you BW 48 too?
How are you getting on with the Adaptive chassis comtrol?  I think its amazing. In comfort it rides better then my Mk6 Golf Match!
Loving it
Ian
2017 MY Golf R 3dr DSG | Lapiz Blue | Dynaudio | Heated Screen | Advanced Phone | Sat Nav | Winter Pack
Offline Mark V GTD
« Reply #7 on: 22 January 2014, 10:18 »
To be fair - its not a common option so he may not have even seen a car with it fitted....
Offline chazzypuk
« Reply #8 on: 22 January 2014, 13:09 »
Hey,
Were you BW 48 too?
Loving it
Ian
Hi yeah I was BW48 :-) I am loving the whole car and the adaptive chassis control is ace! :-) I usually leave it in comfort too and then sport when I want a little play! I am treating it gently though as it doesn't have many miles on the clock!
Offline GTI-7-Performance
« Reply #9 on: 22 January 2014, 21:54 »
On the touch screen you can set 'high beam assist' or 'light assist' or 'dynamic light assist' - or whatever it's called - to on or off. It is activated by pushing the left stalk away for a couple of seconds.
A headlight symbol with and 'A' on it appears in the bit between the speedo and rev counter. It only works in excess of 60kph/40mph and outside of street-light areas (and only at night of course).
When it's on full beam the blue icon lights up. Although it doesn't have just full and dipped - it swings and winks and dives all over the place avoiding other cars...
