Author Topic: fueling  (Read 10579 times)
Offline Craigwilson
fueling
« on: 19 January 2014, 22:51 »
what can cause an 8v digifant to over fuel, and before you say blue temp sender or ecu both have been replaced. it over fuels and won't start as it's flooded and when I force it to start it reeks of petrol and runs horrible
Offline notenoughtime
Re: fueling
« Reply #1 on: 19 January 2014, 22:54 »
sticky plunger in metering unit?
Offline Mr Blue
Re: fueling
« Reply #2 on: 19 January 2014, 23:13 »
digifant not the K-jet.  :smiley:
First common question: Does the fuel pump prime for 3 seconds with ignition on or run continuously?
Offline Craigwilson
Re: fueling
« Reply #3 on: 19 January 2014, 23:24 »
it's primes normally, I don't see anything abnormal with the car but it just won't fire unless I unplug the injectors to clear the fuel from it, and the plugs are soaking wet with petrol. I replaced the plugs and it started perfectly for a while (still running crap tho) and now it's back to not starting. whole ignition systems been replaced
Re: fueling
« Reply #4 on: 20 January 2014, 00:09 »
Only thing I can think off is that the fuel pump relay is sticking.
Offline gazareth
Re: fueling
« Reply #5 on: 20 January 2014, 00:13 »
I would check the fuel pressure regulator and the return pipe coming off it for blockage. would also check fuel pressure.
Offline clipperjay
Re: fueling
« Reply #6 on: 20 January 2014, 10:34 »
1) get plastic coke bottles and stick the injectors into start car
2) check each injector of spray pattern and speed at which they all should fill up.
3) check injector loom they get brittle due to being near the manifold.
4) either faulty injectors are stuck open or loom is earthing out.
5) Fuel relay check it
Offline gazareth
Re: fueling
« Reply #7 on: 20 January 2014, 20:21 »
if you can get the car to run at all take a long flat screwdriver and put the tip of it on each injector and your ear against the handle. you should be able to hear the injectors ticking quite clearly. if not check the wiring back to the ecu. if the wiring is fine then it looks like an ecu fault.
Offline Craigwilson
Re: fueling
« Reply #8 on: 20 January 2014, 22:33 »
apologies I should probably let you know what I've done already, I've replaced my blue sender my ecu my injector loom( got a good one off ebay as mine had been repaired) the loom came with injectors and rail and regulator and I checked them before putting them in by plugging in an old dizzy and turning it with my hand when the ignition is on, my hall sender and cap are new my leads are new I've swapped the relay with my other 8v and done a continuity test of all my plugs and switches going to the ecu.
Offline Craigwilson
Re: fueling
« Reply #9 on: 20 January 2014, 22:35 »
still nothing, it's been over a week now
