Author Topic: rear axle  (Read 1271 times)
Offline Scott D
rear axle
« on: 18 January 2014, 10:54 »
is there any difference between rear axle's across the range of FWD models or is the same part used regardless of engine type?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: rear axle
« Reply #1 on: 18 January 2014, 11:00 »
same I think mate
Offline Scott D
Re: rear axle
« Reply #2 on: 18 January 2014, 13:01 »
cheers bud
do all seem to be the same
