Author Topic: which handbrake cables  (Read 2408 times)
Offline Screech16v
  • MK3 20vt AGU
« on: 17 January 2014, 16:06 »
Mk2 now has mk3 gti rear axle and discs, Mk2 gti handbrake cables have been tried on but look about 7" too short, what cables do I need thanks
Shell is 1986 btw so early model if that helps
« Last Edit: 17 January 2014, 16:54 by Screech16v »
Offline Gambit
Re: which handbrake cables
« Reply #1 on: 17 January 2014, 18:28 »
You want late mk2 golf handbrake cables, 89 onwards, they are longer
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 17 January 2014, 19:28 »
yeah but how much longer we are talking 7"s
Offline Gambit
« Reply #3 on: 17 January 2014, 19:34 »
Yes they route different on later cars hence longer, hence telling you to get later cables!
Offline Screech16v
  • MK3 20vt AGU
« Reply #4 on: 17 January 2014, 19:46 »
Ok cheers will have a look!
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 17 January 2014, 21:08 »
Right ive been looking around and found some 1800mm cables that should do the job  ,the difference is where they attach at the handbrake lever,where early mk2 attach under the lever requiring a longer cable,the later attach behind the lever  ,I never knew there where two kinds!
« Last Edit: 17 January 2014, 21:12 by Screech16v »
Offline Gambit
« Reply #6 on: 17 January 2014, 21:15 »
correct :)
