Golf mk4
Wazzzer
windscreen washers
Topic: windscreen washers (Read 1225 times)
Scottymk4
Here all the time
windscreen washers
17 January 2014, 11:59 »
how do you change where the washers are hitting on the screen?
Dalo Harkin
Re: windscreen washers
17 January 2014, 12:20 »
Ive always used a pin of some kind and moved where the jet hits
look inside the jet and there is a hole its on a kind of ball swivel joint, just move to desired area
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
paultownsend
17 January 2014, 14:06 »
i thought you cant adjust as they are the fan type?
Scottymk4
Here all the time
17 January 2014, 14:25 »
Yeah it's the fan type, just seems to hit low on the screen
Golf mk4
Wazzzer
windscreen washers
