Author Topic: Boost gauge  (Read 2028 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Boost gauge
« on: 16 January 2014, 22:33 »
Can some1 tell me wer I feed the vacuum hose through to my boost gauge ?
Thanks  :smiley:
Offline davemk4
Re: Boost gauge
« Reply #1 on: 17 January 2014, 07:05 »
Fed mine through where ecu sits engine bay .
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline Dalo Harkin
Re: Boost gauge
« Reply #2 on: 17 January 2014, 09:29 »
people run them through the grommet where the cable is for the bonnet release
Offline Gary#turbo
Re: Boost gauge
« Reply #3 on: 17 January 2014, 10:13 »
Ohhh okay
Any idea wer it comes out from that grommet ?
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Boost gauge
« Reply #4 on: 17 January 2014, 10:14 »
^^ +1 for the bonnet release
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Dalo Harkin
Re: Boost gauge
« Reply #5 on: 17 January 2014, 10:36 »
Ohhh okay
Do you mean inside the cabin or inside the bonnet, on the bonnet its on the drivers side inner wing down the channel, follow the line cable from the bonnet release  :wink:
from the cabin its behind the pull lever, just follow it
Offline Gary#turbo
Re: Boost gauge
« Reply #6 on: 17 January 2014, 11:21 »
Ohh I get you now lol
Will have a go at it when my hose comes 4 it  :smiley:
Offline brewey
Re: Boost gauge
« Reply #7 on: 17 January 2014, 17:55 »
I used the grommet at the back of the glove box. It goes into the pollen filter housing and then into the bay. Mines been in for about 8k+ now and no problems.
2000 1.8T ARZ - OEM+
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Boost gauge
« Reply #8 on: 17 January 2014, 18:49 »
I came through the grommet in the door/wing gap
Offline Gary#turbo
Re: Boost gauge
« Reply #9 on: 18 January 2014, 22:55 »
Got any pics mate ?
