Author Topic: Removing Bluetooth - coding needed?  (Read 2786 times)
Offline johnboylds
« on: 16 January 2014, 19:00 »
Hi guys, looking for a bit of help!
I'm looking at moving to a Mk7, and so before trade in I want to remove the RCD510 and Bluetooth from my Mk6 and put the original RCD310 back in.
If I remove the bluetooth will there be any coding needed to tell the car it's no longer there? What would happen if I don't 'decode' it?
Cheers,
John
Offline ajmoir36
Re: Removing Bluetooth - coding needed?
« Reply #1 on: 16 January 2014, 20:08 »
Not sure what will happen if you don't decode it out. But I am sure its as simple as coding the gateway to turn it off. So that the car doesn't think it should have one.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline johnboylds
« Reply #2 on: 16 January 2014, 21:34 »
Cheers AJ - I don't have Vagcom so can't uncode it.
I've suddenly realised though the the simplest thing to do might be to unplug the BT module and see what happens! Not sure why I didn't think of that first!
Offline p3asa
« Reply #3 on: 16 January 2014, 21:56 »
I fitted an RNS510 in mine and had to have it coded. When I traded it in I removed it and replaced it with an RCD510 and no further coding required.
Don't know if it will be similar to yours but I wouldn't imagine it would need coded.
Offline Dan.B
« Reply #4 on: 17 January 2014, 06:47 »
Unplug the module and remove.
No coding required when I done it  :cool:
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 17 January 2014, 13:57 »
If you don't "de-code" it you'll get an error in the central electrics module for no comms with telephone ecu but it won't really affect anything, you won't get any dash lights or warnings etc.
Offline RedHP
« Reply #6 on: 17 January 2014, 19:14 »
^Agreed. As going 'down' in system and especially as both RCD's then you shouldn't see any issues at the front-end, just error messages within
Red
Mk6 GiT since birth in 2010
YNWA
Offline Itteh
  • Built Not Bought
« Reply #7 on: 18 January 2014, 12:40 »
Interested in the Bluetooth module if you're selling!!
Offline johnboylds
« Reply #8 on: 01 May 2014, 20:15 »
Only just seen this as I was going to update the thread. I'll PM you.
I removed the RCD510 and bluetooth at the weekend, no error messages on the dash but I'm not sure if there are any codes being thrown if it was hooked up to diagnostics.
The dashboard seemed so dull without the colour screen!
