Author Topic: vvt chain tensioner  (Read 1170 times)
Offline davidgtrr34
vvt chain tensioner
« on: 15 January 2014, 18:39 »
i have a very loud knocking noise coming from the head so i removed the cam cover i was going to remove the tappets to check to see if the noise was coming from them. i noticed that the vvt chain tensioner can be moved by hand and when i cranked the engine it would go up and down. the car has not being started for 2 weeks and has no oil in it for 3 days. should the tensioner be able to move or should it be solid
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline rockmonkey69
Re: vvt chain tensioner
« Reply #1 on: 15 January 2014, 22:24 »
Yes it runs off oil pressure, so it will be slack if it's not had oil pumping through it for weeks. The noise is likely the hydraulic lifters.
« Last Edit: 15 January 2014, 22:27 by rockmonkey69 »
Offline davidgtrr34
« Reply #2 on: 17 January 2014, 23:03 »
cheers. im going checking the oil pressure and if its normal ill pull the lifters out to check them
Offline mar_k
« Reply #3 on: 18 January 2014, 15:12 »
Ignore my ramblings
Offline Bellend
« Reply #4 on: 18 January 2014, 18:00 »
Just a tip for leaving oil to drain for ages is to crank with no ignition. There are particular Fords that I will actually do this to anyway even with a quick oil change.
Where all my moneys went.
