Author Topic: Climate control lighting wont fully light!  (Read 2172 times)
Offline WeekendMechanic
  • Golf MK3 GTD
« on: 15 January 2014, 15:06 »
So I replaced the bulb for a led bulb, that did not work then I bought two more led lights drilled to holes in the shield.
Ok got a bright heat circle but on the left ,on the fan speed only the number 4 lights up, and the ducting control only has 1/4 of the circle lit, help it is really bugging me anyone have a fully lit climate control mind telling me what he did to restore it after 20 years?
VW BUSH
Re: Climate control lighting wont fully light!
« Reply #1 on: 15 January 2014, 19:56 »
My dimmer wheel was the fault behind my lighting woes.
Not sure if this affects climatronic
  • Golf MK3 GTD
« Reply #2 on: 15 January 2014, 21:17 »
Thaanks,Mine is not climatronic but the normal one dimmer seems to be working fine how can I check it and be certain?
« Last Edit: 15 January 2014, 21:21 by WeekendMechanic »
VW BUSH
« Reply #3 on: 15 January 2014, 21:31 »
I managed to bypass mine, the replacement unit lasted about 3 months :grin:
Since then I have just put up with a half lit dash devoid of enthusiasm to fix (bodge) it :grin:
Offline kodkod.84
« Reply #4 on: 16 January 2014, 07:35 »
Have you made sure the clear plastic conduit which the light has to pass through is connected back up properly?
Mine had the same fault when I replaced the bulb and it was because this clear plastic wasn't sitting properly against the dials
