Author Topic: Dial swap  (Read 1512 times)
Offline paul yeo
Dial swap
« on: 15 January 2014, 13:33 »
Heard different things about dial swaps on a mk4 golf. Is it just plug and play?
Offline navmk4gti
Re: Dial swap
« Reply #1 on: 15 January 2014, 14:27 »
If you mean changing the clocks...then no you need to get them coded in and you cannot do it with vagcom.
Offline paul yeo
Re: Dial swap
« Reply #2 on: 15 January 2014, 15:21 »
Ok where can I get this done? My mpg has given up in my dials and it's really annoying. Thanks
Offline navmk4gti
Re: Dial swap
« Reply #3 on: 15 January 2014, 16:13 »
Drop a thread in vagcom section mate.. see anyone local to you has the software to do it.. i have some bora clocks i need coding in too.. where are you based?
Offline mcgee9t2
Re: Dial swap
« Reply #4 on: 15 January 2014, 17:59 »
only certain clocks work depending on the clocks you currently have, iirc you can swap to a better set of clocks i.e. immo2 clock - immo3 clocks, but not to a worse set of clocks i.e. immo3 clcoks -immo2 clocks cannot be done.
theres a thread in the maintenance section on them sorry thread was actually on ukmkivs
as said you will need them coding though.
list of forum vagcom owners, have a search see if anyone is local to you and drop them a pm stating you will give them a few beer tokens for there time and im sure someone will help. if not, garage job it is, or try get a hookie copy of vagcom from somewhere and buy vagcom light (buy it for the lead, you cannot code clocks with vagcom light iirc, and saves you buying a cheep lead and it not working)
« Last Edit: 15 January 2014, 18:06 by mcgee9t2 »
Offline paul yeo
Re: Dial swap
« Reply #5 on: 17 January 2014, 21:46 »
Ok thanks for your help. I'm based in porthleven Cornwall
