Author Topic: Big Problem! Now Solved  (Read 8652 times)
Offline Len
« on: 13 January 2014, 16:44 »
Cambelt pulley on end of crank is wrong!!!! :angry:
The diesel crank has a flat section whereas the 16v abf has a notch in it.
The diesel pulley has less teeth so the cam belt wont fit it!
Makes me wonder as if you read the forums ClubGti etc. many people say they have done the same engine conversion as me but they dont have the same problems!
They telling porkies or have kept quiet about the problems????
Anyway think I need and engineering shop with a milling machine!
« Last Edit: 17 January 2014, 15:45 by Len »
www.sas.org.uk
www.the-ace.org.uk
Offline boneybradley
  • Back in a Mk3...
Re: Big Problem!
« Reply #1 on: 13 January 2014, 17:34 »
abf crank pulley is 26 teeth and the diesel 22 (I don't know if that helps in any way?)
also abf timing belt has number of teeth 151 and width 25mm
Offline tweed
Re: Big Problem!
« Reply #2 on: 13 January 2014, 18:44 »
Run a diesel cam belt?
  • Back in a Mk3...
Re: Big Problem!
« Reply #3 on: 13 January 2014, 19:07 »
diesels are 137 tooth belts
Offline Len
Re: Big Problem!
« Reply #4 on: 13 January 2014, 19:36 »
Cant!
Wont fit the camshaft pulley nor the secondary pulley that drives the oil pump!
www.sas.org.uk
www.the-ace.org.uk
Offline Len
Re: Big Problem!
« Reply #5 on: 13 January 2014, 19:38 »
No it doesnt help!  :grin:
I just found that out today!
The real problem is how they fit onto the end of the crank itself.
I cant see any way round this other than getting the abf one machined to fit!
www.sas.org.uk
www.the-ace.org.uk
Offline spikenipple
Re: Big Problem!
« Reply #6 on: 13 January 2014, 20:57 »
Len, drop me a PM with some pics and a description of what you need done and I'll machine it for you for return postage/a pint  :wink:
VW BUSH
Re: Big Problem!
« Reply #7 on: 13 January 2014, 21:24 »
Timing will be out wont it?
I would just get the right one
Offline gazareth
Re: Big Problem!
« Reply #8 on: 13 January 2014, 23:42 »
don't think there is a right one when you fit a diesel crank into an abf block.
Offline gazareth
Re: Big Problem!
« Reply #9 on: 13 January 2014, 23:45 »
I would machine the crank as if you take any metal off the pulley it might weaken it.
