Author Topic: Tramping - any long term affects?  (Read 15807 times)
Offline GrahamFR
Re: Tramping - any long term affects?
« Reply #20 on: 14 January 2014, 09:20 »
youre probably just a better driver :smiley:
And what about switching it to sport mode?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline FNJ-GTI
« Reply #21 on: 14 January 2014, 09:28 »
Had my first experience of this on the way to work this morning. Pretty cold out (car told me it was 2oC), came up to a roundabout and when I pulled away a got a massive judder / clonking noise. I assume this is Tramping? gave me a bit of a shock as ive not experienced it before.
Offline GrahamFR
« Reply #22 on: 14 January 2014, 09:34 »
pretty much mate, sounds painful dont it
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline titusrider
« Reply #23 on: 14 January 2014, 09:42 »
looks like this  :shocked:
Collected Jan 4th: MK7 gti, red, 3dr, PP, DCC (dampers), Dynaudio, Nav
Offline corgi
« Reply #24 on: 14 January 2014, 11:03 »
I drive in sport mode, almost exclusively...
Corgi
Offline corgi
« Reply #25 on: 14 January 2014, 11:09 »
Yes, that's certainly axle tramp... in that case the spinning wheel twists the axle against the leaf spring, lifting the wheel, the twisting motion is instantly reduced, the suspension "untwists" and the wheel settles back... repeat ad nauseum.
The effect that is being experienced on the golf is, I suspect, the front strut twisting longitudunally under load... the potential damage is done when the wheel(s) spinning freely in the air hit the ground - can cause damage to driveshafts, joints, gearbox, diff, suspension components, springs, dampers - probably not in the short term but over time wear will be increased...
Corgi
Offline GrahamFR
« Reply #26 on: 14 January 2014, 11:55 »
But is there not a separate section for the asr in the car menu?
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline GrahamFR
« Reply #27 on: 14 January 2014, 20:48 »
Lol I can confirm that turning the asr to sport does feck all for the for the tramping!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Geomets
« Reply #28 on: 15 January 2014, 18:04 »
You can either switch off the ASR or (by pressing for three seconds) enable the sports mode. I was meaning switching it off completely.
Offline GrahamFR
« Reply #29 on: 15 January 2014, 18:11 »
So you don't have to go through all the menus that's a good bit of Info there 'thanks
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
