Author Topic: mk4 2.0 gti starting issue  (Read 1100 times)
Offline smithyvr6
« on: 11 January 2014, 22:46 »
Hi guys,ive owned my golf for 2 years now and until a couple of weeks has been trouble free.When I went to start it,it didn't start.It turned over but didn't fire so I had a quick look and checked the obvious.I had a look on the net and went back out about 30-40 minutes later and it started.It ran fine with no issues once started but it done the same yesterday.Has anyone had a similar issue or can point me in the right direction.
Offline davidgtrr34
Re: mk4 2.0 gti starting issue
« Reply #1 on: 11 January 2014, 22:53 »
I had the same problem but on a tdi Passat and it was the fuel pump
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline smithyvr6
« Reply #2 on: 11 January 2014, 23:00 »
did you test the pump or just change it?
Offline davidgtrr34
« Reply #3 on: 11 January 2014, 23:07 »
didn't have to test it cause it gave up completely while I was driving. was doing 60mph and the engine died to make it worse I was 2 hour from home
Offline smithyvr6
« Reply #4 on: 11 January 2014, 23:26 »
oh...I don't want to drive it to far now for the same reason.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 11 January 2014, 23:40 »
Might be worthwhile getting it checked for any fault codes with vag-com first
2000 Mkiv GTi 1.8T AGU
Offline davidgtrr34
« Reply #6 on: 11 January 2014, 23:44 »
he's right get it scanned if you can. but if it is the pump then it wont show up on vagcom
