Author Topic: idle speed stabilisation valve  (Read 1875 times)
Offline rids
« on: 11 January 2014, 18:54 »
Hi all, new here, I'm running a bog standard unmolested mk 2 Gti on 150000 miles. i have a slight problem that i have traced to the idle stabilisation valve,  my question is, can i run without it with both pipes blanked off?  can these valves be cleaned? or is it worth buying new?
cheers
rids
Offline dragonfly
Re: idle speed stabilisation valve
« Reply #1 on: 11 January 2014, 19:20 »
Clean it first.  Remove the valve and squirt some carb cleaner down both holes until there is not debris coming out.  Dry off and re-install.
