Author Topic: VCDS and error code problem  (Read 4856 times)
Offline andygo
« on: 11 January 2014, 17:06 »
I have just changed the water pump on my Mk6 2009 gti. Everything seemed to go well until I started the car up and got the eml light. Both rad fans were running from cold.
The error codes I have seem to be related to the water temp sensor. Had everyting to bits, reassembled, same codes pop up. Tried my old temp sensor, no difference. Everyting seems to be plugged in, car runs fine, although I haven't dropped off the axle stands yet. The error codes relating to the radio have been there for ages, but the radio works fine, so not bothered too much about that!
 Any ideas folks?
Friday,10,January,2014,14:27:10:06433
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ1KZA*****   License Plate:
Mileage:    Repair Order: POST SWAP 1
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 47 52 56
VIN: WVWZZZ1KZAW0****
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH03---    Serial number:
   Coding: 0403000C18070160
   Shop #: WSC 01357 011 00200
   VCID: E7DDDADED6747526B59-80B2
1 Fault Found:
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 000 - Signal too High - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82221 km
                    Time Indication: 0
                    Date: 2051.14.01
                    Time: 14:13:41
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 11.938 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
   Component: ESP MK60EC1   H45 0108
   Revision: 00H45001
   Coding: 163B600D892400FA681406ED912000813008
   VCID: 7DF118B6E4E84FF6FF5-8028
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
   Component: Climatronic   H14 0608
   Revision: 00003001
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 6DD128F6BC88DF764F5-8038
1 Fault Found:
13701888 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 87
                    Mileage: 82221 km
                    Date: 2051.14.01
                    Time: 14:13:48
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
   Component: BCM PQ35  M   103 0537
   Revision: 00103 AC
   Coding: 48180A3A9825F10044080080140001E443510088536D8960648000200000
   VCID: 306FF182633A729E243-8065
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 20050  21  0501
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 030609 05  54  0402
   Coding: 0330AD
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2R02WB14
   Coding: 00003233
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360_VW01.rod
   VCID: F7FD8A9E4ED4E5A6259-80A2
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 230D6447ZZZZZZZZZZZZ
   Crash sensor for side airbag; passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 2A2A3248ZZZZZZZZZZZZ
   Crash sensor for side airbag; rear driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3C2D2945ZZZZZZZZZZZZ
   Crash sensor for side airbag; rear passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 343C2900ZZZZZZZZZZZZ
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           855 0111
   Coding: 0000532
   VCID: 78FF09A20BCA6ADEAC3-802D
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Shop #: WSC 00000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 B    HW: 5K6 920 970 B
   Component: KOMBI         H05 0206
   Serial number: 00000000000000
   Coding: 470900
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 3365FE8E9A2C4986591-8066
1 Fault Found:
13639424 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 87
                    Mileage: 82221 km
                    Date: 2051.14.01
                    Time: 14:13:41
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 290509F2000333
   Coding: E9801F06100212000001
   VCID: 66C357DA517EEC2E0EF-8033
2 Faults Found:
00469 - Infotainment Databus in Single Wire Operation
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 254
                    Reset counter: 87
                    Mileage: 71867 km
                    Time Indication: 0
                    Date: 2045.14.12
                    Time: 18:01:34
03272 - Control Module for Audio Interface
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 71867 km
                    Time Indication: 0
                    Date: 2045.14.12
                    Time: 18:01:38
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H05 0206
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2108
   Coding: 0004662
   VCID: 326BFB8AAD36408E527-8067
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H15000
   VCID: 2F6DF2FEBE046D663D9-807A
Address 47: Sound System (R12)       Labels: None
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218198603915
   ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
   ROD: EV_AudioVerst8KanalBNO1.rod
   VCID: 55A16016341877B6975-8000
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0004918
   VCID: 3365FE8E522C4986591-8066
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  037 0144
   Revision: 00000001    Serial number: VWZ1Z3I4263929
   Coding: 0701000001
   VCID: E5C1D0D6EC786736875-80B0
3 Faults Found:
00857 - CD Changer Unit (R41)
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 71867 km
                    Time Indication: 0
                    Date: 2045.14.12
                    Time: 18:02:39
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 71867 km
                    Time Indication: 0
                    Date: 2045.14.12
                    Time: 18:02:37
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 73
                    Mileage: 71867 km
                    Time Indication: 0
                    Date: 2045.14.12
                    Time: 18:02:39
End   ---------------------------------------------------------------------
