Author Topic: Advice ?  (Read 2080 times)
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
Advice ?
« on: 10 January 2014, 23:47 »
I know this is already posted but I have a lot if water going into my rear passenger footwell on drivers side
I get it out n by the next morning it's back ther
Iv changed the air pollen filter but it hasn't helped ,
It's a 5door with a sunroof
Is ther Anyfin behind the passenger rear door that might need resealing
I fitted a boost gauge but cud that cause such a leak ?
 Please help !! Lol  :cry:
Offline houston
Re: Advice ?
« Reply #1 on: 11 January 2014, 00:03 »
Go into the boot and flip the n/s panel open, reach right through to the corner of your car, as far as you can reach, can you feel a puddle? There's a grommet there you can remove so it doesn't get as bad but you will need to reseal the breather vent that's beneath bumper
Offline mcgee9t2
Re: Advice ?
« Reply #2 on: 11 January 2014, 01:27 »
Isn't that o/s? Along with the vent?
Could be a number of things.
Pollen filter cover
Door seals
Window regulator panel seals
Hole in floor
Rubber grommet through firewall (behind glovebox) commonly used for amps and not sealed (though if there's a lot of water it so proberbly not this)
Sun roof seals
Door drains
Boot vent
Offline Gary#turbo
Re: Advice ?
« Reply #3 on: 11 January 2014, 10:11 »
Okay I will have a good check today
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Advice ?
« Reply #4 on: 11 January 2014, 10:47 »
Just had this myself, turned out to be the regulator panel not sealing properly. All sealed up now and been running a heater and de-humidifier in the car the last few evenings at work; taken about a litre of water out so far!
Offline Gary#turbo
Re: Advice ?
« Reply #5 on: 11 January 2014, 11:14 »
What's the regulator panel lol
Offline Gary#turbo
Re: Advice ?
« Reply #6 on: 11 January 2014, 15:53 »
I put a gauge in and cowboyed the boost tube
Does any reckon this could cause the leak in the rear footwell
Cuz I hoovered it up and an hour later the water was bk in the footwell but it hasn't rained today
Do you think this cud b excess water what left in the car ?
image hosting 10mb limit
Offline navmk4gti
Re: Advice ?
« Reply #7 on: 11 January 2014, 16:25 »
Im sure thats the sunroof drain that you have blocked up
Offline houston
Re: Advice ?
« Reply #8 on: 11 January 2014, 19:35 »
Pollen filter cover
Door seals
Hole in floor
Sun roof seals
Door drains
Boot vent
No, n/s. There's a channel that directs the water to the back seats.
Could be the rear screen wash pipe is leaking if it hasn't been raining?
Offline Gary#turbo
Re: Advice ?
« Reply #9 on: 11 January 2014, 20:51 »
Rear screen wash wiper is fine
I'm hoping it's this nipple I posted earlia
