Author Topic: [Solved] Malfunction on Mk2 16V MFA  (Read 1522 times)
Offline Beastlee
« on: 18 October 2003, 13:24 »
Hi all,
We just bought an 89(F) 16V and have noticed a couple of strange effects on the MFA, namely :
1. Cannot reset either mode by holding the switch to the reset point.
2. It doesn't reset after 2 hours with the ignition off.
 (only way to reset is to disconnect battery)
It seems to me that the switch thinks it's locked in the 2(total) position, is this common?  We can get a new stalk for it for ?20 but I'd rather check it out first rather than waste the money.
Thanks
Lee
« Last Edit: 28 August 2005, 13:11 by Beastlee »
89(F) Mk2 16V
Helios Blue w. Big Bumpers
17" Alloys and 40mm Lowered
Blue Hella Rear Lenses
Big ICE Install
Offline Beastlee
Re: Malfunction on Mk2 16V MFA (Solved)
« Reply #1 on: 28 August 2005, 13:10 »
Just noticed I never showed this as fixed.  The PCB ribbon had been damaged and I have now managed to repair it by soldering wires across the break.  All is fine with it now.
Lee
89(F) Mk2 16V
Big ICE Install
