Golf mk3
hardmonkeys
MK3 GTI 94 8v
Topic: MK3 GTI 94 8v (Read 3109 times)
atesh
Just got here
MK3 GTI 94 8v
10 January 2014, 12:21 »
HI guys i have mk3 gti 94 8v
it backfires when driving , i recently had the airflow meter repLACED, set the timing ,changed dizzy cap,replaced relay 30, changed fuel pump ..but it still backfires ..can any1 help me
chris_d66
Golf GTI 16v,A3 1.8t,Rocco, Range rover V8
Re: MK3 GTI 94 8v
10 January 2014, 12:35 »
Do a Compression check at the same time condition of your plugs and leads.
Can you tell if it is back fireing in to the exhaust (over fueling) or inlet manifold (lean), connect to the ecu to check for error codes.
May be worth while going in to the FAQ section of this forum.
New toy1990 Scirocco I feel a 16v conversion coming on.
GOLF-MK3-GTI
Re: MK3 GTI 94 8v
10 January 2014, 15:31 »
When does it back fire? Idle or when under load? Also check if spark plugs are gapped properly?
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: MK3 GTI 94 8v
10 January 2014, 15:34 »
why did you get all those parts replaced? for the backfiring issue? or did backfiring start after getting ignition adjusted?
also good to know when it backfires....
2E run well when they run well, but if they act up god are they b!tches....
atesh
Just got here
Re: MK3 GTI 94 8v
13 January 2014, 15:05 »
thanx chris ..its backfires through inlet manifold ...then after couple kms through the exhaust
atesh
Just got here
Re: MK3 GTI 94 8v
15 January 2014, 07:32 »
hi ...i have changed the ht leads ..stil backfires but only we driving its fine if its idling..
Leon27
Here all the time
Re: MK3 GTI 94 8v
Reply #6 on:
15 January 2014, 20:56 »
Backfiring from the inlet may be attributed to a wrong firing order.
Did it only start back firing after you changed the leads then?
itavaltalainen
Re: MK3 GTI 94 8v
Reply #7 on:
16 January 2014, 18:05 »
+1 for firing order
or:
ignition timing massively out (was hall sender replaced recently?)
or:
cambelt slipped
xionsolaris
Here all the time
Re: MK3 GTI 94 8v
Reply #8 on:
16 January 2014, 20:48 »
is it misfiring ?
Golf mk3
hardmonkeys
MK3 GTI 94 8v
