Author Topic: gearbox oil vr6  (Read 2209 times)
Offline Outlawsaffa1982
gearbox oil vr6
« on: 08 January 2014, 20:55 »
Evening all.
What oil do i need to use in my vr6 gearbox?  I got some castrol multi application the other day but it feels a bit knotchy when changing threw the gears, im thinking the oils not viscus enough...
Any thoughts?
Offline itavaltalainen
Re: gearbox oil vr6
« Reply #1 on: 08 January 2014, 21:25 »
synthetic 75w90 - ideally one that is for gearboxes and diffs (lasts better)...
I used Total Syn Fe 75w90 in the past and was pleasantly surprised of how much it helped my old mk3 gearbox :)
Re: gearbox oil vr6
« Reply #2 on: 08 January 2014, 21:28 »
Great! Il give it a bash!
Re: gearbox oil vr6
« Reply #3 on: 09 January 2014, 22:44 »
Ok! So after doing a bit more reading and research I found a very helpful thread on the vr6oc forum!
They are suggesting Redline mt-90, gonna give it a go and see what's what!
Re: gearbox oil vr6
« Reply #5 on: 09 January 2014, 23:06 »
MT90 is a synthetic 75w90, from data sheet looks marginally better than the Total Syn FE 75w90.
TBH you probably won't notice a huge difference between the two of them (or other synth. 75w90's), either will make it much better than with the 15-20 year old gunk that in there now.
