Author Topic: GTD Windscreen wipers confused  (Read 2575 times)
Offline adekil
« on: 08 January 2014, 17:26 »
Noticed on my drive home today that placing the windscreen wiper from intermittent to normal and they were on fast, moved up to last notch and what should be the fast mode and they went down to normal speed! Repeated this a few times to be sure I wasn't doing anything wrong (not like you can really) and got the same results then on about the 5th or 6th go the order was back to how I expect, intermittent, normal then fast
ho hum
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
Offline Mark V GTD
Re: GTD Windscreen wipers confused
« Reply #1 on: 08 January 2014, 19:52 »
On a GTD there is no 'intermittant' setting - thats the 'auto' setting which might explain spome of the speed differentials you experienced?
« Last Edit: 08 January 2014, 19:54 by Mark V GTD »
Offline GTI-7-Performance
« Reply #2 on: 10 January 2014, 07:05 »
It's unclear if you have a rain sensor or not. If so the notches/switch settings control the sensitivity of the rain sensor.
In heavy rain the wiper speed will switch to fast when required when on rain sensor...
Offline adekil
« Reply #3 on: 10 January 2014, 07:12 »
This was experienced on the normal and fast setting not the rain sensor setting.
