Author Topic: Central locking only working from interior swtich  (Read 3017 times)
Offline russ-vdub
  • Once a Dub, Always a Dub
« on: 07 January 2014, 12:49 »
Alright Boys & Girls!
Got a the problem above with my missus car, the key doesn't activate all doors so she has to open manually, put the key in the ignition, turn the key, then unlock all the other doors to prevent the alarm going off. Very long winded!
Anyone had the same problem and might know what's up?
Cheers!
EDIT: Apologies for the double post, my internet at work is more than turd
« Last Edit: 07 January 2014, 12:51 by russ-vdub »
Offline russ-vdub
Re: Central locking only working from interior swtich
« Reply #1 on: 19 February 2014, 12:08 »
No one :(
Offline topher
  • Administrator
  • fully functioning
« Reply #2 on: 21 February 2014, 13:15 »
Tried a new battery in the key fob?
Offline russ-vdub
« Reply #3 on: 24 February 2014, 13:32 »
Yeah tried all the obvious things. Manually unlocking using the key, not the button doesn't even open the doors which is strange imo.
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 24 February 2014, 19:30 »
Assuming the interior lights and electric windows are still working it's unlikely to be the fuse for the ccm but check all the fuses anyway. Could be a fault with the ccm or can gateway, you'll need to find someone local who's handy with vagcom to go any further (must be can compatible the £10 ebay jobbies won't work)
Offline russ-vdub
« Reply #5 on: 25 February 2014, 12:14 »
yeh all the lights work etc and it locks the whole car via the key ok. We had a look on my mates Vagcom before and nothing actually showed up :/ Will have another go but I just can't see why it wont unlock all doors
Offline itavaltalainen
« Reply #6 on: 25 February 2014, 22:05 »
get a full auto scan for all control modules with vcds...
Offline russ-vdub
« Reply #7 on: 04 March 2014, 18:02 »
What will that do? Its been vagcom's and reset to no avail
Offline russ-vdub
« Reply #8 on: 26 March 2014, 13:38 »
turns out the missus was a lying cnut so no worries about this any more ;)
