Author Topic: Rear passenger footwell puddle  (Read 1563 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 07 January 2014, 10:54 »
With all this rain we've had the Golf has sprung a leak and it's a big one. I emptied out about a litre of water from the footwell yesterday and I've got about the same today  :cry:
I can't find anything obvious and searches have thrown up all sorts of ideas from the pollen filter (not likely as it's only the rear) to the sunroof (if I had one)
Has anyone had this and what were their solutions? I want to rid the car of the water as it's annoying having to bail out every day plus I can't be doing with the condensation. I've got a fan heater running in there to dry it out now
One thing I am going to try at the weekend is resealing the window mech panel as I had this off in the summer to replace the window runner...
Offline dom
  • Back in a Mk4
Re: Rear passenger footwell puddle
« Reply #1 on: 07 January 2014, 11:28 »
You damaged a sill/door didn't you? Checked the door is still sealing properly?
Offline mcgee9t2
« Reply #2 on: 07 January 2014, 12:53 »
copied from the other water thread
have you had your regulator panel off? check that its all sealed still. both of mine leaked, the first i didnt know you had to reseal i thought the rubber would provide a seal, the second i resealed with butyl tape but it came un sealed when a bit of water was in the door and freezed causing the panel to push away...
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 07 January 2014, 19:13 »
Just on my break at work so I thought I'd pull the panel off and it's soaking behind it. So I've half pulled it off and run some weather sealant tape (like strong blue tac) round the bottom half so this should hopefully stop it.
I'm leaving the door card off as we're meant to get a lot of rain tonight so I can see if it's solved it. Definitely found the source though :afro:
Offline davidgtrr34
« Reply #4 on: 07 January 2014, 20:51 »
check the rubber seal where the bonnet cable goes through the firewall
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Gary#turbo
  • 100%boostaddict http://www.golfgtiforum.co.uk/inde
« Reply #5 on: 07 January 2014, 21:36 »
Which door did u do ?
Iv got same problem with mine
Loadsa water in rear passenger footwell behind drivers seat
Iv Gota sunroof but I changed the pollen filter n it's no good so need more ideas
Thanks
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 08 January 2014, 12:22 »
Threw it down most of the night last night and no sign of a leak :afro:
The door panel I fitted on there was distorted with some of the rubber seal breaking off in my hands so with a bit of persuading with a hammer it's sealing properly where it needs to along with the sealant tape I've added :wink:
Will be sticking a dehumidifier in there over the weekend along with a heater to finally get rid of all the condensation that's been building up
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« Reply #7 on: 14 January 2014, 11:12 »
Just noticed I got the same issue in mine. Serious case of leakage :cry:
What did you reseal and where? Any pics?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
