Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47626 times)
Offline jivemonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #60 on: 11 January 2014, 14:12 »
Oooo i'm tempted......
What could go wrong, hehehe
Translation is a bit hit and miss directly, so using some Google 'did you mean?' came up with the above..
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline noobmonkey
« Reply #61 on: 11 January 2014, 14:15 »
Hmmmm - can't find it to change it?!
Edit - Found it... *Holding breath!*
« Last Edit: 11 January 2014, 14:26 by noobmonkey »
VW Golf MK7 GTD Manual 5DR Pure White
Offline jivemonkey
« Reply #62 on: 11 January 2014, 14:22 »
Should be in the Access Control 2 section, here's the listings coming up to it:
(17)-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt
(18)-Access control 2-Spiegelverstellung Synchron
(19)-Access control 2-Kessy Komfort oeffnen
(20)-Access control 2-Kessy Komfort schliessen
(21)-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung
(22)-Access control 2-Menuesteuerung Spiegelabsenkung
(23)-Access control 2-Funk Spiegelanklappen
(24)-Access control 2-Funk Spiegelanklappung Modus
(25)-Access control 2-Menuesteuerung synchrone Spiegelverstellung
(26)-Access control 2-Menuesteuerung Funk Spiegel anklappen
(27)-Access control 2-Menuesteuerung Komfortbedienung einstellbar
(28)-Access control 2-Menuesteuerung Regenschliessen
(29)-Access control 2-SAD PreCrash Konturschliessen
(30)-Access control 2-FH SAD Kl15Aus Freigabezeit
(31)-Access control 2-Fahrertuerbedienung Fensterheber oeffnen
(32)-Access control 2-Fahrertuerbedienung Fensterheber schliessen
(33)-Access control 2-Remote_Unlock_Lock
(34)-Access control 2-Profilfunktion f¸r Anklappung der Auflenspiegel
Channel numbers may vary!
Offline noobmonkey
« Reply #63 on: 11 January 2014, 14:30 »
Meh....
Error - Security access required
Offline mcmaddy
« Reply #64 on: 11 January 2014, 14:30 »
security code starts with a 3 doesn't it?? 31347 is mentioned in another post.
Offline noobmonkey
« Reply #65 on: 11 January 2014, 14:33 »
ok, past the security part... changed it....
Nada....
Well nothing i can see
Offline noobmonkey
« Reply #66 on: 11 January 2014, 14:35 »
Offline mcmaddy
« Reply #67 on: 11 January 2014, 14:35 »
might need to cycle an engine start up a lock and an unlock etc for it to work. you did exit the controller from vcds didn't you??  :wink: :grin:
Offline noobmonkey
« Reply #68 on: 11 January 2014, 14:37 »
lol yes! :P
And did that, full off, full back on, engine up, and did it 2 more times to make sure :)
Offline jivemonkey
« Reply #69 on: 11 January 2014, 14:39 »
lol yes! :P
Good effort though! I assume the fold on lock still operates?
