Author Topic: Anyone with a Post BW45 car got VCDS?  (Read 47623 times)
Offline jivemonkey
Re: Anyone with a Post BW45 car got VCDS?
« Reply #40 on: 10 January 2014, 14:16 »
hehe think i screwed up with that bit...
Set the foggies as the lights fine, and then set the shirp on lock only, it does however seem to have disabled the coming home lights whilst doing it... doh!
How do you mean disabled the coming home lights? Is it enabled in the MFD? Does it work when flashing the main beam? Going to do foggies next I think. I assume they just turn off after either the leaving home timer expires, or ignition is turned on?
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline jivemonkey
« Reply #41 on: 10 January 2014, 14:45 »
If you need any more info just say as I'm home now so I can pop back out to the car
Jason
Jason, would you be able to assist me in checking central electrics adaptation channel values for pre and post BW45 cars? I came across this guide:
http://www.audienthusiasts.com/Article_VCDSAdaptationMap.html
which is a bit clearer and more suited to what we need to do than the Ross-Tech version:
http://www.ross-tech.com/vcds/tour/controller-channels-map.html
...which is very similar apart from the CSV/ adaptation selection.
If we can compare the mirror fold related channels and see if there't any obvious discrepancies, we could be on to a winner hopefully.
I'll do my pre-45 tonight.
Offline jmc
« Reply #42 on: 10 January 2014, 14:51 »
Will do when I get home tonight
VW Golf VII, GTD, manual, Night Blue, Rear view camera.
Offline jivemonkey
« Reply #43 on: 10 January 2014, 15:03 »
Great - thanks for your time and help, appreciate you already have these tweaks we're after!
Offline noobmonkey
« Reply #44 on: 10 January 2014, 15:04 »
They used to just come on! (Not tested the flashy lighty thingy! - will try that shortly :) )
VW Golf MK7 GTD Manual 5DR Pure White
Offline jivemonkey
« Reply #45 on: 10 January 2014, 15:16 »
Not on the Mk6 or 7 as far as I'm aware, you have to flash your main beams to activate it! You can enable it to come on automatically with VCDS, should be in the main thread..
Offline noobmonkey
« Reply #46 on: 10 January 2014, 15:23 »
Yup aware of that (What i did originally) - so i disabled it by accident :P hehe
Offline jivemonkey
« Reply #47 on: 10 January 2014, 17:33 »
Well, it took about 20 minutes but have the list now! Some interesting entries on their. It's about 1700 lines long! Think we'll need to send to compare..
Interested in the below:
(1)-Access control 2-Komfortbedienung global      active
(2)-Access control 2-Comfort opening                      not active
(3)-Access control 2-Comfort closing                      active
(24)-Access control 2-Funk Spiegelanklappung Modus    by look command via remote control key
(34)-Access control 2-Profilfunktion f¸r Anklappung der Auflenspiegel   not active
« Last Edit: 10 January 2014, 17:54 by jivemonkey »
Offline jmc
« Reply #48 on: 10 January 2014, 19:42 »
Just sat in the car now as it dose its thing ......
Offline jivemonkey
« Reply #49 on: 10 January 2014, 19:48 »
Best get comfy... :grin:
