Author Topic: problems with 02 sensor  (Read 1378 times)
Offline lee1989
« on: 06 January 2014, 12:36 »
keep getting this code,
 16518 - Oxygen (Lambda) Sensor B1 S1
            P0134 - 35-10 - No Activity - Intermittent
have changed it twice and still getting it, im thinking its a wiring problem but is there anything else that could cause this fault code?? thanks in advance
Offline mar_k
Re: problems with 02 sensor
« Reply #1 on: 06 January 2014, 13:11 »
What sensor did you change?
B1 S1 is the one in the downpipe.
Just want to confirm the correct sensor was changed.
Also what year is your car? Does it have DBW?
Offline lee1989
« Reply #2 on: 06 January 2014, 13:14 »
Yes mate changed the pre-cat 1, and its a 2001 aqy cheers
Offline lee1989
« Reply #3 on: 12 January 2014, 09:19 »
Anything else i should look for as im going to take a look today cheers
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 12 January 2014, 21:52 »
Wiring...
Offline lee1989
« Reply #5 on: 12 January 2014, 21:59 »
Thats what im thinking Just not sure if anything else could cause the same problem :)
