Author Topic: Reconditioned, Refurbishment and fitting of my AUM engine?  (Read 1369 times)
Offline Hiddenbhp
hi guys need some help my block has gone up the shoot well not completely, i have bent the conrod on cylinder No.4:( Im looking at getting a second hand AUM block weather it be second hand or reconditioned or just get mine refurbed or buy one thats refurbed. but all this being well I also have no idea where I can get it fitted!
I was wandering if anyone could advise which way would be the cheapest or if anyone has any recommendations on where to take it to have work done or the new block fitted, you hear so many stories of bad work, dodgy warentee's and sting alongs.
Offline mar_k
Re: Reconditioned, Refurbishment and fitting of my AUM engine?
« Reply #1 on: 05 January 2014, 21:30 »
I wouldn't replace the block, I'd inspect the bores and if they are good I'd replace the rods and go steel instead of
fitting another block with standard rods.
Offline Hiddenbhp
« Reply #2 on: 05 January 2014, 22:01 »
how much will this set me back though? im just thinking once i start taking it all apart and stripping down it might be a snowball effect?
Offline mar_k
« Reply #3 on: 05 January 2014, 22:14 »
Depends what rods you use and who is doing the work.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 05 January 2014, 22:55 »
tbh if it was me i would be inclined to do the work myself and get the sump and head etc off as it can be done engine in situ and inspect the bore and big end pin then source a rod and swap onto the piston or get a short engine which would be possibly cheaper than a full engine ie you get the block ,crank,pistons etc then use your head sump etc means abit of work but its all do able shame your so far away as i would liked to have done the work for you and helped a fellow forum member out.
2000 Mkiv GTi 1.8T AGU
Offline mar_k
« Reply #5 on: 05 January 2014, 23:41 »
I have a set of standard rods here I would sell for £40
Offline madmanmart
« Reply #6 on: 06 January 2014, 18:07 »
I have a AUQ short engine here (same as AUM).
70k miles, £100
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
